Enables network login logout pop-up window.
Enabled.
This command controls the logout window pop-up on the web-based network client. This command applies only to the web-based authentication mode of network login.
The following command enables network login logout-privilege:
enable netlogin logout-privilege
This command was first available in ExtremeXOS 11.1.
