Configures an OSPFv3 area as a normal area.
| area_identifier | Specifies an OSPFv3 area, a four-byte, dotted decimal number. |
Normal.
Virtual links can be configured through normal areas. External routes can be distributed into normal areas.
The following command configures an OSPFv3 area as a normal area:
configure ospfv3 area 10.1.0.0 normal
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
