Removes the join limit set on VLAN ports.
| vlan_name | Specifies a VLAN name. |
| port_list | Specifies one or more ports or slots and ports. |
No limit.
None.
The following command removes the join limit for port 2:1 in the Default VLAN:
unconfigure igmp snooping "Default" ports 2:1 set join-limit
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IGMP snooping feature, see the Switch Engine v33.1.1 Licensing Guide document.
