Enables the EDP on one or more ports.
ports |
Specifies one or more ports or slots and ports, including management port. |
all |
Specifies all ports on the switch, including management port. |
Enabled.
On a SummitStack, ports can be a list of slots and ports. On a stand-alone switch, ports can be one or more port numbers. For a detailed explanation of port specification, see Port Numbering in Command Reference Overview
EDP is useful when Extreme Networks switches are attached to a port.
Switch MAC address (switch ID).
Switch software version information.
Switch IP address.
Switch VLAN information.
Switch port number.
Switch port configuration data: duplex, and speed.
The following command enables EDP on port 3 on a switch:
enable edp ports 3
The port configuration data was added in ExtremeXOS 11.0.
Ability to enable EDP on management port was added in ExtremeXOS 30.1.
