This command shows the current captive portal configuration for web-redirects, L4 listening ports, and rule use space programming.
| redirect_index | Shows the particular web redirect index indicated (1–10). |
| all | Shows all web redirect indexes. |
| listening | Shows captive portal HTTP listening L4 ports. |
| web-redirect | Shows web redirect information. |
| rule-use | Shows captive portal rule use. |
N/A
The following example shows the currently configured captive portal L4 listening ports:
# show policy captive-portal listening Captive Portal Listening Ports: 55 33 22
The following example shows the currently configured captive portal servers from all web-redirect indexes:
# show policy captive-portal web-redirect
Web-redirect Index: 1
Server Index: 2
Server Status: enabled
Server URL: http://192.168.1.3:5552/path/to/use
Web-redirect Index: 10
Server Index: 2
Server Status: disabled
Server URL: http://111.222.22.33:802/path/to/use
The following example shows all of the captive portal servers at web-redirect index 1 (regardless of configuration):
# show policy captive-portal web-redirect 1
Server Index: 1
Server URL:
Server Index: 2
The following example shows the entire captive portal configuration:
Server Index: 1
Server URL:
Server Index: 2
Web-redirect Index: 2
Server Index: 1
Server URL:
Server Index: 2
Server URL:
Web-redirect Index: 3
Server Index: 1
Server URL:
Server Index: 2
Server URL:
Web-redirect Index: 4
Server Index: 1
Server URL:
Server Index: 2
Server URL:
Web-redirect Index: 5
Server Index: 1
Server URL:
Server Index: 2
Server URL:
Web-redirect Index: 6
Server Index: 1
Server URL:
Server Index: 2
Server URL:
Web-redirect Index: 7
Server Index: 1
Server URL:
Server Index: 2
Server URL:
Web-redirect Index: 8
Server Index: 1
Server URL:
Server Index: 2
Server URL:
Web-redirect Index: 9
Server Index: 1
Server URL:
Server Index: 2
Server URL:
Server Index: 1
Server URL:
Server Index: 2
# show policy captive-portal rule-use Captive Portal Rule Use: Reserved
This command was first available in ExtremeXOS 22.3.
The rule-use option was added in ExtremeXOS 30.4.
