Allows you to add a GRE tunnel. This command is in-line with adding an ipv6-in-ipv4 tunnel.
| gre | Generic Routing Encapsulation tunnel. |
| destination-address | IPv4 destination address of the tunnel. |
| source-address | IPv4 source address of the tunnel. |
| vr | Specifies configuring the tunnel on specific VR. |
| vr_name | Specifies which VR to configure the tunnel on. This VR if the VR of the tunnel itself, where source-address is configured. It is the underlay/delivery. This is the source outer IP address. The default is the VR of the current context. |
| payload-vr | Specifies a tunnel payload VR (VR of the tunnel interface). |
| payload_vr_name | Specifies the tunnel payload VR name. It is the VR of the L3 interface of the tunnel, that is, the payload/overlay. The default is the VR of the tunnel. |
No GRE tunnels exist in the system.
When adding tunnels, the VR of the current context is the default unless otherwise specified.
By default, the payload VR is the VR of the tunnel.
Use this command to add a GRE tunnel.
create tunnel myGREtunnel gre destination 10.0.0.2 source 10.0.0.1
This command was first available in ExtremeXOS 15.3.
Ability to configure GRE tunnels on user VRs was added in ExtremeXOS 31.3.
This command is available on the platforms listed for the GRE feature in the Switch Engine v33.1.1 Licensing Guide document.
