configure bgp peer-group route-reflector-client
configure bgp peer-group peer-group-name [route-reflector-client | no-route-reflector-client]
Description
Configures all the peers in a peer group to be a route reflector client.
Syntax Description
peer-group-name Specifies a peer group.
route-reflector-client Specifies that all the neighbors in the peer group be a route reflector client.
no-route-reflector-client Specifies that all the neighbors in the peer group not be a route reflector client.
Default
N/A.
Usage Guidelines
This command implicitly defines this router to be a route reflector.
This command applies to the current VR or VRF context.
The peer group must be in the same AS of this router.
The following command configures the peer group outer as a route reflector client:
configure bgp peer-group outer route-reflector-client
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
