Administratively disables one or all static LSPs.
| lsp_name | Identifies an LSP to be disabled. |
| all | Specifies that all static LSPs on this LSR are to be disabled. |
N/A.
On executing this command, the software de-activates the specified LSPs by setting the administrative state of each LSP to down.
The following command disables a static LSP:
disable mpls static lsp lsp598
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
