Displays a counter for each component of a switch that shows how long it has been functioning since it was manufactured.
N/A.
The output from this command displays how long individual components in the switch have been functioning since it was manufactured. This odometer counter is kept in the EEPROM of each monitored component.
Depending on the software version running on your switch and the type of switch you have, additional or different odometer information may appear.
The following command displays how long each component of a switch has been functioning since its manufacture date:
show odometers
The following is sample output from a stand-alone switch:
Service First Recorded Field Replaceable Units Days Start Date ------------------------- ------- -------------- Switch : SummitX 7 Dec-08-2004 Service First Recorded Field Replaceable Units Days Start Date --------------------------------------------------------------- Switch : X(SS) 381 Oct-29-2009 VIM1-SS-1 : 376 Jul-30-2009
