This command has been replaced with the following command: configure l2vpn [vpls [vpls_name | all] | vpws [vpws_name | all]] health-check vccv {intervalinterval_seconds} {fault-multiplierfault_multiplier_number} .
This command is still supported for backward compatibility, but it will be removed from a future release, so we recommend that you start using the new command.
Configures the VCCV health check test and fault notification intervals for the specified VPLS instance.
| vpls_name |
Identifies the VPLS instance for which health check is to be configured. |
| all |
Specifies that the configuration applies to all VPLS instances on the local node. |
| interval_seconds |
Defines the interval between health check tests. The range is 1 to 10 seconds. |
| fault_multiplier_ number |
Specifies how long health check waits before a warning level message is logged. The wait period is the interval_seconds multiplied by the fault_multiplier_number. The fault_multiplier_number range is 2 to 6. |
Interval is 5 seconds.
Fault mulitplier is 4.
The VCCV health-check configuration parameters can be configured at anytime after the VPLS has been created.
The show l2vpn {vpls {{vpls_name} | vpws {{vpws_name}} {peeripaddress} {detail} | summary} command displays the configured interval_seconds and fault-multiplier_number values for the VPLS and the VCCV activity state.
The following command configures the health check feature on the VPLS instance myvpls:
configure vpls myvpls health-check vccv interval 10 fault-notification 40
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
