Displays the IP ARP security violation information for one or all VLANs.
| vlan_name | Specifies a single VLAN for which to display security violation information. |
| vlan_list | Specifies a VLAN list of IDs to display security violation information. |
Shows security violation information for all VLANs except Mgmt.
None.
The following example displays IP ARP security violation information for all VLANs:
Switch.4 # show iparp security Most Recent Violation ========================================== Vlan Security Violations Type IP address MAC Port ====================================================================================== Default ---- test ---- Security Setting: (G) Gratuitous ARP Protection Violation Type : (g) Gratuitous ARP Violation
The following example displays IP ARP security violation information for VLAN Default:
Switch.5 # show iparp security "Default" Most Recent Violation ========================================== Vlan Security Violations Type IP address MAC Port ====================================================================================== Default ---- Security Setting: (G) Gratuitous ARP Protection Violation Type : (g) Gratuitous ARP Violation
The vr option was added in ExtremeXOS 11.0.
The vlan_list variable was added in ExtremeXOS 16.1.
