Configures a pre-defined event that triggers the named profile.
| upm-event | Specifies a pre-defined event type: device-detect, device-undetected, user-authenticate, user-unauthenticated. |
| profile-name | Specifies the profile to be configured. |
| port-list | Attaches the UPM profile to the specified port(s). |
N/A.
This command configures a profile to be executed when the specified event occurs on the specified port(s).
You can configure multiple user profiles on the same port(s).
The following example shows how to configure a profile on port 1:1, called “profile 1” that is triggered by the event “device-detect”:
# configure upm event device-detect profile "p1" ports 1:1
This command was first available in ExtremeXOS 11.6.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the Universal Port feature, see the Switch Engine v33.1.1 Licensing Guide document.
