Displays the FTP file synchronization configuration for NVPP and VMMAP files.
| primary | secondary | Specifies whether you are displaying the primary or secondary FTP server configuration. |
If you do not specify primary or secondary, the default action is to display both the primary and secondary FTP server configurations.
None.
The following command displays the configuration for the primary and secondary FTP servers:
# show vm-tracking repository Primary VM-Map FTP server: Server name: IP address : 10.100.1.200 VR Name : VR-Mgmt Refresh-interval: 600 seconds Path Name : /pub (default) User Name : anonymous (default) Secondary vm-map FTP server: Unconfigured Last sync : 16:35:15 Last sync server : Primary Last sync status : Successful
This command was first available in ExtremeXOS 12.5.
