This command configures the minimum time required to wait before regenerating the same LSP.
| area_name | Specifies the router process for which you want to configure the LSP generation interval. |
| seconds | Specifies the generation level in seconds. The range is 1 to 120 seconds. |
| level | Specifies the level to which you want to apply the configuration. If neither level 1 nor level 2 is specified, the configuration applies to both levels. |
30 seconds.
In link flapping situations in a mesh network, this can greatly reduce the amount of network traffic generated from LSP flooding.
The following command sets the LSP generation interval to a value of 40 seconds:
configure isis area areax timer lsp-gen-interval 40
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
