Exports direct, static, and BGP routes from a VRF into BGP, running on the specified VR, as EVPN routes to be advertised by BGP as Type 5 routes.
bgp | Specifies showing the BGP configuration. |
export | Specifies redistributing information from another routing protocol. |
static | Specifies static routes. |
direct | Specifies direct routes. |
address-family | Specifies the address family. |
address_family | Sets the address family type. |
l2vpn-evpn | Specifies the L2VPN EVPN address family. |
vr | Specifies the source VR. |
vr_name | Designates the source VR name. Both VPN-VRFs and non-VPN-VRFs are supported. |
N/A.
N/A.
The following example exports static routes on VR "vr-a" as EVPN routes to be advertised by BGP as Type 5 routes:
# enable bgp export static l2vpn-evpn vr vr-a
This command was first available in ExtremeXOS 30.6.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
