Disables DHCP snooping on the switch.
| vlan_name | Specifies the name of the DHCP-snooping VLAN. |
| dynamic | Configuration options for dynamically created VLANs. |
| all | Specifies all ports to stop receiving DHCP packets. |
| ports | Specifies one or more ports to stop receiving DHCP packets. |
By default, DHCP snooping is disabled.
Use this command to disable DHCP snooping on the switch.
The following command disables DHCP snooping on the switch:
disable ip-security dhcp-snooping vlan snoop ports 1:1
This command was first available in ExtremeXOS 11.6.
Dynamic VLAN option added in ExtremeXOS 30.2.
