Enables CLI command authorization.
Disabled.
When enabled, each command is transmitted to the remote TACACS+ server for authorization before the command is executed. TACACS+ authentication must also be enabled to use TACACS+ authorization. Use the following command to enable authentication:
enable tacacsThe following command enables TACACS+ command authorization for the switch:
enable tacacs-authorization
