Displays the source IP lockdown configuration on the switch.
N/A.
Port—Indicates the port that has DHCP snooping enabled and is configured for source IP lockdown.
Locked IP Address—Indicates a valid DHCP-assigned address obtained by a DHCP snooping-enabled port or an authenticated static IP address.
The following command displays the source IP configuration on the switch:
show ip-security source-ip-lockdown
The following is sample output from this command:
Ports Locked IP Address 23 10.0.0.101
This command was first available in ExtremeXOS 11.6.
