Unconfigure MRP timers, or only reset the MRP timer values to default if the timer keyword is specified.
| mrp | Multiple Registration Protocol. |
| ports | Ports on which MRP timers are to be configured. |
| all | All ports. |
| timers | Multiple Registration Protocol timers. |
| refresh | Timer value to use in place of regular leave timer, only in cases when leave-all is received or sent. |
| join | The time interval to delay sending MRP advertisements. |
| leave | The time interval to wait in the leaving state before transitioning to the empty state. |
| leave-all | The time interval used to control the frequency of "leave all" messages. |
| periodic | The time interval between two periodic events. |
The default values for join, leave, leave-all, are 200, 600, and 10000, respectively. The default values for join, leave, leave-all, periodic and extended-refresh timers are 200, 600, 10000, 1000, and 0 milliseconds, respectively.
Use this command to unconfigure MRP timers, or only reset the MRP timer values to default if the timer keyword is specified. If none of the timers are specified, this command resets all three timers to the default values. The default values for the join, leave, and leave-all timers are 200, 600, and 10000 ms respectively.
unconfigure mrp ports all unconfigure mrp ports all timers unconfigure mrp ports all timers join
This command was first available in ExtremeXOS 15.3.
The extended-refresh and periodic timer options were added in 15.3.2.
