This command turns Extreme Loop Recognition Protocol (ELRP) on/off for client ports or uplink ports for dynamic VLANs.
| netlogin | Specifies that the command applies to dynamic VLANs created by Network Login only. |
| vm-tracking | Specifies that the command applies to dynamic VLANs created by virtual machine MAC tracking only. |
| client-ports | Specifies client ports only. |
| uplink-ports | Specifies uplink ports only. |
| remote-endpoints | Specifies remote endpoints that are part of this VLAN. |
| vxlan | Specifies VXLAN remote endpoints that are part of this VLAN. |
| on | Enable ELRP for dynamic VLANs. |
| off | Disables ELRP for dynamic VLANs. |
ELRP for dynamic VLANs is "off" by default.
The following example enables ELRP for Netlogin dynamic VLANs on uplink ports only:
configure elrp-client dynamic-vlans netlogin uplink-ports on
configure elrp-client dynamic-vlans vm-tracking remote-endpoints vxlan on
This command was first available in ExtremeXOS 22.2.
Remote endpoint capability was added in ExtremeXOS 22.4.
