Deletes a user-defined mirroring instance, and unconfigures the "DefaultMirror" instance.
| mirror_name |
Specifies a specific mirror name to delete. |
| control_index |
Mirror destination control index (1–4). Also know as: etsysMirrorDestinationControlIndex. Each comprises a group of mirror names. |
| all |
Specifies that you delete all named mirror instances. |
Disabled.
Use this command to delete a user-defined mirroring instance and unconfigure the "DefaultMirror" instance. Mirroring instances must be in the "disabled" state in order to be deleted. The all command will fail if any mirroring instance is in the "enabled" state.
The following example deletes all mirroring instances:
delete mirror all
This command was first available in ExtremeXOS 15.3.
Variable control_index to support policy-based mirrors was added in ExtremeXOS 30.2.
