disable fdb static-mac-move
Description
Disables EMS and SNMP reporting of discovered MAC addresses that are duplicates of statically configured MAC addresses.
Syntax Description
Default
Disabled.
Usage Guidelines
None.
The following example disables this feature:
This command was first available in ExtremeXOS 12.7.
Platform Availability
