Disables the EAPS function for a named domain or for an entire switch.
| name | Specifies the name of an EAPS domain. |
Disabled for the entire switch.
Enter y to disable EAPS for a specific domain or the entire switch.
Enter n or press [Return] to cancel this action.
If you have considerable knowledge and experience with EAPS, you might find the EAPS loop protection warning messages unnecessary. For more information, see the configure eaps config-warnings off.
The following command disables the EAPS function for entire switch:
disable eaps
The switch displays the following warning message and prompts you to confirm this action:
WARNING: Disabling EAPS on the switch could cause a loop in the network! Are you sure you want to disable EAPS? (y/n) Enter y to disable EAPS on the switch. Enter n to cancel this action.The following command disables the EAPS function for the domain eaps-1:
disable eaps eaps-1
WARNING: Disabling specific EAPS domain could cause a loop in the network!Are you sure you want to disable this specific EAPS domain? (y/n)Enter y to disable the EAPS function for the specified domain. Enter n to cancel this action.
This command was first available in ExtremeXOS 11.0.
The interactive messages were added in ExtremeXOS 11.4.
