Deletes a MAC address from the MAC address tracking table.
| mac_addr | Specifies a device MAC address, using colon-separated bytes. |
| all | Specifies that all MAC addresses are to be deleted from the MAC address tracking table. |
The MAC address tracking table is empty.
None.
The following example deletes a MAC address from the MAC address tracking table:
delete fdb mac-tracking entry 00:E0:2B:12:34:56
This command was first available in ExtremeXOS 12.3.
