Deletes an IPv6 tunnel.
| tunnel_name | Specifies an IPv6 tunnel. |
N/A.
This command will destroy a previously created tunnel. The command acts on either a 6to4 or a 6in4 tunnel. When the tunnel interface is removed, all dynamic routes through that interface are purged from the system. The configured static routes are removed from the hardware tables and become inactive.
The following example deletes the tunnel link39:
delete tunnel link39
This command is available on the platforms listed for the IPv6 interworking feature in the Switch Engine v33.1.1 Licensing Guide document.
