Configures the switch RADIUS client to an NMS for VM authentication.
primary | secondary |
Specifies the whether you are configuring the primary or secondary NMS. |
ipaddress |
Specifies the NMS IP address. |
hostname |
Specifies the NMS DNS hostname. |
udp_port |
Specifies the UDP port number of the NMS application. |
client_ip |
Specifies the client IP address, which is the switch IP address on the interface leading to the NMS. |
encrypted |
Specifies that the secret key for communications with the NMS is encrypted. |
secret |
Specifies a key or password for communications with the NMS. |
vr_name |
Specifies the VR that is used to access the NMS. |
N/A.
The NMS is a RADIUS server such as the one provided with Ridgeline.
The following command configures the switch to authenticate VMs through the primary NMS server Ridgeline using the password password:
# configure vm-tracking nms primary server Ridgeline client-ip 10.10.3.3 shared-secret password
This command was first available in ExtremeXOS 12.5.
