This command has been replaced with the following command: unconfigure l2vpn [vpls vpls_name | vpwsvpws_name] dot1q ethertype .
This command is still supported for backward compatibility, but it will be removed from a future release, so we recommend that you start using the new command.
Unconfigures the ethertype setting for the VPLS specified by vpls_name.
| vpls_name | Identifies the VPLS within the switch (character string) |
N/A
This command unconfigures the ethertype setting for the VPLS specified by vpls_name. The setting is changed back to the value displayed in the show dot1q command.
The following command changes the ethertype setting for the specified VPLS to the value displayed in the show dot1q command:
unconfigure vpls my_vpls dot1q ethertype
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
