Creates a new profile of a specified type.
| profile-name | Specifies the UPM profile to be created. |
N/A.
Use this command to create a profile and name it. The maximum profile size is 5000 characters.
A UPM profile name must begin with an alphabetical character and may contain alphanumeric characters and underscores (_), but it cannot contain spaces. The maximum allowed length for a name is 32 characters. For name creation guidelines and a list of reserved names, see Object Names.
There is a limited capability to edit the profile with this command. If you enter a period (.) as the first and the only character on a line, you terminate the editing of the file. Use the command: edit upm profile profile-name for block mode capability.
The following example shows how to create a profile named "P2":
# create upm profile p2 enable port 2:* disable port 3:1
This command was first available in ExtremeXOS 11.6.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the Universal Port feature, see the Switch Engine v33.1.1 Licensing Guide document.
