Displays the port information portion of the circuit ID for the indicated port(s).
| port_list | Specifies one or more ports. |
| all | Specifies all ports. |
N/A.
This command displays the port information portion of the circuit ID for the indicated ports.
# show ip-security dhcp-snooping information circuit-id port-information ports 1-7
Port Circuit-ID Port information string ---- ---------------------------------- 1 portinfostring1 2 portinfostring2 3 portinfostring3 4 portinfostring4 5 portinfostring5 Port Circuit-ID Port information string ---- ---------------------------------- 6 1006 7 1007 Note: The full Circuit ID string has the form '<Vlan Info>-<Port Info>'
This command was first available in ExtremeXOS 12.3.
