show ospfv3
show ospfv3
Description
Displays global OSPFv3 information.
Syntax Description
Default
N/A.
Usage Guidelines
None.
The following command displays global OSPFv3 information:
show ospfv3
The following is sample output:
OSPFv3              : Disabled           RouterId            : 0.0.0.0
RouterId Selection  : Automatic          ASBR                : No
ABR                 : No                 ExtLSAs             : 0
ExtLSAChecksum      : 0x0                OriginateNewLSAs    : 0
ReceivedNewLSAs     : 0                  SpfHoldTime         : 3s
Num of Areas        : 1                  LSA Batch Interval  : 0s
10M Cost            : 100                100M Cost           : 50
1000M Cost (1G)     : 40                 2500M Cost (2.5G)   : 40
5000M Cost (5G)     : 40                 10000M Cost (10G)   : 20
25000M Cost (25G)   : 20                 40000M Cost (40G)   : 20
50000M Cost (50G)   : 20                 100000M Cost (100G) : 10
Graceful Restart    : None               Grace Period        : 120s
Import Policy File  : none
SNMP Traps          : Disabled
Redistribute:
  Protocol               Status    Cost      Type  Tag    Policy
  direct                 Disabled  20        2     ---    none
  e-bgp                  Disabled  20        2     ---    none
  i-bgp                  Disabled  20        2     ---    none
  ripng                  Disabled  20        2     ---    none
  static                 Disabled  20        2     ---    none
  isis-level-1           Disabled  20        2     ---    none
  isis-level-2           Disabled  20        2     ---    none
  isis-level-1-external  Disabled  20        2     ---    none
  isis-level-2-external  Disabled  20        2     ---    none
  host-mobility          Disabled  20        2     ---    none
The 40G parameter was added in ExtremeXOS 12.6.
SNMP trap status information was added in ExtremeXOS 22.1.
Platform Availability
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
