This command disables VM-tracking dynamic VLAN on specific ports.
Disabled.
Use this command to disable VM-tracking dynamic VLAN on specific ports. The ALL option is not supported because VM-tracking dynamic VLAN should not be enabled on a switch's uplink port.
# disable vm-tracking dynamic-vlan ports 2:1
This command was first available in ExtremeXOS 15.3.
