Displays the readings of the global BFD counters.
N/A.
Use this command to display global BFD counters.
To clear the counters, use the clear counters bfd command.
The following command displays BFD global counters:
# show bfd counters Valid Tx Pkt : 177 Valid Rx Pkt : 177 Rx Invalid TTL : 0 Rx Invalid UDP SrcPort : 0 Interface Not found : 0 Rx Invalid Version : 0 Rx Invalid Length Pkt : 0 Rx Invalid Multiplier : 0 Rx Invalid Demand Mode : 0 Rx Poll & Final set : 0 Rx Invalid My Discriminator : 0 Rx Invalid Your Discriminator : 0 Rx Invalid Auth Length : 0 Rx session Not Found : 6 Auth Type Fails : 0 Authentication Fails : 0 Tx Fails : 0 Rx Discarded Pkt : 0 Rx Invalid Multipoint : 0
The Rx session Not Found counter is incremented when the BFD session corresponding to the received BFD packet is not found. The Rx Discarded Pkt counter is incremented when the neighbor state indicated in the BFD packet is not one of the expected/allowed states.
This command was first available in ExtremeXOS 12.4.
Rx Invalid Multipoint information was added in ExtremeXOS 30.7.
