Creates a maintenance domain (MD) in the string name format and assigns an MD level to that domain.
                                 str_name  |
                                 Enter a character string to specify part of the domain name. The maximum length is 43 characters.  |
                                 level  |
                                 Specifies the MD level you are assigning to this domain. Enter a value between 0 and 7.  |
N/A.
You can have up to 8 domains on a switch, and each one must have a unique MD level.
You assign each domain a maintenance domain (MD) level, which function in a hierarchy for forwarding CFM messages. The levels are from 0 to 7; with the highest number being superior in the hierarchy.
5 to 7 for end users
3 and 4 for Internet service providers (ISPs)
0 to 2 for operators (entities carrying the information for the ISPs)
The following command creates a domain, using the string format having a value of extreme; it also assigns that domain an MD level of 2:
create cfm domain string extreme md-level 2
This command was first available in ExtremeXOS 11.4.
