Configures the priority for out of memory shutdown.
| ipv4 | Configures a PIM timer on IPv4 router interfaces. |
| ipv6 | Configures a PIM timer on IPv6 router interfaces. |
| vlan_name | Specifies a VLAN name. |
| all | Specifies all VLANs. |
| number | Priority for VLAN range is [0 - 65535]. |
IPv4.
None.
config pim vlan v36 shutdown-priority 22
This command was first available in ExtremeXOS 12.4.
The ipv4 and ipv6 keywords were added giving an option to support this functionality in IPv6 as well in ExtremeXOS 15.3.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.1.1 Licensing Guide document.
