Changes the router identifier.
| router identifier | Specifies a router identifier in the IPv4 address format. |
N/A.
BGP must be disabled before changing the router ID.
This command applies to the current VR or VRF context.
The following command changes the router ID:
configure bgp routerid 192.1.1.13
To remove the configured bgp routerid, give routerid value as 0.0.0.0 i.e. configure bgp routerid 0.0.0.0.This command was first available in ExtremeXOS 10.1.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
