Unconfigures the guest VLAN feature for 802.1X authentication.
port_list | Specifies one or more ports included in the guest VLAN. |
vlan_name | Specifies all ports included in the guest VLAN. |
N/A.
Use this command to unconfigure the guest VLAN for 802.1X authentication.
If you do not specify one or more ports or the VLAN name, this command unconfigures all of the 802.1X ports configured for the guest VLAN feature.
If you specify one or more ports, this command unconfigures the specified 802.1X ports for the guest VLAN feature.
If you specify the VLAN name, this command unconfigures all of the 802.1X ports configured for the specified guest VLAN.
The following command unconfigures the guest VLAN feature for 802.1X authentication:
unconfigure netlogin dot1x guest-vlan
The ports option was added in ExtremeXOS 11.6.
