This command deletes existing collectors.
| all | Specifies that you delete all report collectors. |
| hostname | Specifies the host name of the collector you want to delete. |
| ip_address | Specifies the IPv4 address of the collector you want to delete. |
Disabled.
This command deletes existing collectors. If you specify all, it deletes all existing collectors; otherwise it deletes the collector specified by the hostname or IP address. If the specified collector does not exist, an error message ERROR: The collector 1.1.1.1 does not exist is displayed.
The following example deletes all collectors :
configure tech-support delete collector all
This command was first available in ExtremeXOS 15.4.
