This command allows you to create a group for an existing local end-point.
| domain_name |
Enter the domain associated with the MA you are configuring. |
| association_name |
IEEE 802.1ag or ITU-T Y.1731 association name. |
| port_list |
Enter the port number you want to configure as either an UP or DOWN MEP. |
N/A.
Use this command to add a group to the association.
configure cfm domain "MD1" association "MD1v1" ports 17 end-point down add group "eapsCfmGrp"
This command was first available in ExtremeXOS 15.2.
