This command disables the stacking-support option on a switch with dual-purpose hardware.
This command does not have additional syntax.
Disabled.
The Stacking-Support Option Control column in ExtremeSwitching Series Switch Support for Alternate Stack Ports displays Yes in the rows for switch configurations for which you can disable the stacking-support option.
After you disable the stacking-support option, you must reboot the switch to activate the configuration change.
If you disable the stacking-support option on a switch and reboot, stacking communication stops and the data ports listed in ExtremeSwitching Series Switch Support for Alternate Stack Ports use Ethernet protocols instead of stacking protocols.
To disable the stacking ports, enter the following command:
# disable stacking-support This setting will take effect at the next reboot of this switch.
This command was first available in ExtremeXOS 12.2.
