For Auto-peering, adds dynamic BOOTP relay servers that the DHCP relay agent uses to forward DHCP traffic received from host attachments.
auto-peering | Specifies Auto-peering. |
one-config | Specifies changing the BGP Auto-peering OneConfig configuration. |
bootprelay | Specifies configuring dynamic BOOTP relay service applied to dynamically created VRFs. |
add | Adds dynamic BOOTP relay server. |
delete | Deletes dynamic BOOTP relay server. |
ip_address | Specifies the IPv4 address of the BOOTP relay server. |
ipv6_address | Specifies the IPv6 address of the BOOTP relay server. |
vr | Specifies selecting the virtual router (VR) If you do not specify a VR or VRF, the current VR context is used. |
vrname | Specifies the VR name. |
Dynamic BOOTP relay services are configured after the dynamic VRF is installed on the device.
The following example adds dynamic BOOTP relay server at "50.1.101.105" for VR "red":
# configure auto-peering oneconfig bootprelay add 50.1.101.105 vr red
This command was first available in ExtremeXOS 31.1.
