Creates an Automation Edge remote VXLAN network identifier (VNI)-device database.
| database | Creates a remote VNI-database. |
| database_name | Specifies the name of the new database. |
N/A.
You can only create one VNI-device database.
The following example creates a database called "database1":
# create database database1
This command was first available in ExtremeXOS 31.1 as a demonstration feature.
This command is fully supported in ExtremeXOS 31.2.
