Configures VLAN ports to support a maximum number of IGMP joins.
vlanname | Specifies a VLAN name. |
portlist | Specifies one or more ports or slots and ports. |
num | Specifies the maximum number of joins permitted on the ports. The range is 1 to 500. |
No limit.
None.
The following example configures port 2:1 in the Default VLAN to support a maximum of 100 IGMP joins:
configure igmp snooping "Default" ports 2:1 set join-limit 100
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IGMP snooping feature, see the Switch Engine v33.1.1 Licensing Guide document.
