This command disables the padding of Hello PDUs for one or all IS-IS VLANs.
| vlan all | Disables hello padding on all IS-IS VLANs. |
| vlan_name | Specifies a single VLAN on which to disable hello padding. |
Enabled.
Implicit adjacency MTU verification is not performed when hello padding is disabled.
The following command disables hello padding on all IS-IS VLANs:
disable isis vlan all hello-padding
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
