Deletes the specified protected VLAN from the specified EAPS domain.
| name | Specifies the name of an EAPS domain. |
| vlan_name | Specifies the name of the protected VLAN. |
N/A.
To prevent loops in the network, you must delete the ring ports (the primary and the secondary ports) from the protected VLAN before deleting the protected VLAN from the EAPS domain. Failure to do so can cause a loop in the network.
If you have considerable knowledge and experience with EAPS, you might find the EAPS loop protection warning messages unnecessary. For more information, see the configure eaps config-warnings off command.
The following example deletes the protected VLAN orchid from the EAPS domain eaps_1:
configure eapseaps_1delete protected vlan orchid
The switch displays the following warning message and prompts you to confirm this action:
WARNING: Make sure EAPS ring-ports are deleted from the VLAN first. Otherwise deleting the VLAN from the EAPS domain could cause a loop in the network! Are you sure you want to remove the VLAN before deleting EAPS ring-ports.? (y/n)
Enter y to delete the VLAN from the specified EAPS domain. Enter n to cancel this action.
This command was first available in ExtremeXOS 11.0.
The interactive messages were added in ExtremeXOS 11.4.
