enable mpls rsvp-te fast-reroute
Description
Enables the MPLS RSVP-TE fast reroute (FRR) protection feature.
Syntax Description
Default
Enabled.
Usage Guidelines
You can configure FRR LSPs only when FRR is enabled on the LSR. Enabling FRR protection on the LSR automatically enables the point-of-local-repair and merge-point capabilities on the LSR. FRR should be enabled on all LSRs along each FRR LSP path.
The following command enables FRR protection on the local switch:
Platform Availability
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
