Moves an interface from one OSPFv3 area to another.
| vlan_name | Specifies an IPv6 configured VLAN. |
| tunnel_name | Specifies an IPv6 tunnel. |
| area_identifier | Specifies an OSPFv3 area, a four-byte, dotted decimal number. |
N/A.
Use this command to move an already configured interface from one area to another. The instance ID associated with the interface will be unchanged.
The following command moves the VLAN accounting to the OSPFv3 area 0.0.0.6:
configure ospfv3 vlan accounting area 0.0.0.6
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
