Displays MPLS statistics for one or all Layer 2 VPNs.
| vpls_name | Specifies VPLS for which to display statistics. |
| vpws_name | Specifies VPWS for which to display statistics. |
| detail | Displays additional information about the Layer 2 VPNs. |
N/A.
None.
The following command displays statistics for all Layer 2 VPNs:
Switch.1 # show mpls statistics l2vpn VPN ID Peer IP RxPackets RxBytes TxPackets TxBytes ------------------------------------------------------------------------------- 99 11.100.100.219 32866 4967734 14005 2394407 11.100.100.218 398 8235 577 10583 2009 11.100.100.219 0 0 0 0 2008 11.100.100.219 0 0 15 688
The following command displays detailed statistics for all Layer 2 VPNs:
Switch.2 # (debug) 12.2 # show mpls statistics l2vpn detail VPNID (L2VPN Name) Peer IP State RxLabel TxLabel LSPTxLabel NextHopI/F RxPackets RxBytes TxPackets TxBytes ------------------------------------------------------------------------------- 99 (jwcvpls) 11.100.100.219 Up x80402 x80402 x00010 tordoze 32866 4967734 14005 2394407 11.100.100.218 Up x80407 x80405 x00011 tornext 398 8235 577 10583 2009 (pws-1) 11.100.100.219 Up x80403 x80403 x00010 tordoze 0 0 0 0 2008 (pws-2) 11.100.100.219 Up x80404 x80404 x00010 tordoze 0 0 15 688
L2VPN Name
Peer IP/LSP Flags RxPackets RxBytes TxPackets TxBytes
vpls1
1.1.1.1 U 0 0 0 0
lsp1 + 0 0
lsp2 + 0 0
Flags: (U) Up, (D) Down, (R) Ready, (S) Signaling, (+) In-use,
(-) Not In-use
This command was first available in ExtremeXOS 12.4.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
