disable ntp vr
disable ntp vr vr_name
Description
This command disables NTP from the specified VR.
Syntax Description
vr Specifies disabling NTP on a VR.
vr_name Specifies the VR name to disable NTP from. If a VR name is not specified, the VR of current command context is used.
Default
The following example disables NTP from a VR named "vr1".
disable ntp vr vr1
This command was first available in ExtremeXOS 22.2.
Platform Availability
