enable ntp broadcast-client
enable ntp broadcast-client {{vr} vr_name}
Description
Enables an NTP broadcast client on the switch.
Syntax Description
broadcast-client Specifies enabling NTP broadcast client.
vr Specifies enabling NTP broadcast client for a VR.
vr_name Specifies the VR name. If a VR name is not specified, the VR of current command context is used.
Default
An NTP broadcast client is enabled by default.
Usage Guidelines
If the broadcast client function is enabled, the system can receive broadcast-based NTP messages and process them only if a VLAN is enabled for NTP and the VLAN is active.
The following command enables an NTP broadcast client on the switch:
This command was first available in ExtremeXOS 12.7.
The vr was added in ExtremeXOS 22.2.
Platform Availability
