configure ospfv3 interface priority
configure ospfv3 [vlan vlan_name | tunnel tunnel_name | [vlan | tunnel] all] priority priority
Description
Configures the priority used in the designated router and backup designated router election algorithm for one or all OSPFv3 interface(s).
Syntax Description
vlan_name Specifies an IPv6 configured VLAN.
tunnel_name Specifies an IPv6 tunnel.
all Specifies all IPv6 configured VLANs or all IPv6 tunnels.
priority Specifies a priority range. The range is 0 through 255.
Default
The default setting is 1.
Usage Guidelines
When two routers are attached to a network, both attempt to become the designated router. The one with the higher priority takes precedence. If there is a tie, the router with the higher router ID takes precedence. Setting the value to 0 ensures that the router is never selected as the designated router or backup designated router.
The following command sets the priority of the interface VLAN corporate to 10:
# configure ospfv3 vlan corporate priority 10
Platform Availability
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
On switches with a Core or Premier license, the non-zero interface priority takes effect; on switches with an Advanced Edge or Base license, the default interface priority is 0.
